DataSources for scripted connector not showing in Dataminer cube
Solved1.78K views2nd April 2025Scripted Connectors
7
Apurva Tandon [DevOps Member]1.73K 24th December 2024 0 Comments
Even though I have set the soft launch for data api as true, it does not show on my dataminer applications and also, the data source I created I cannot see it in surveyor.
Dont know what I am missing here?
Is the script can only be powershell or in python to get information but I also want to get alarms info from multiple dataminer cluster, so for now as alternative I have created a custom API which is used by custom GQI to get the information. Now, I want to write custom connector which should use the custom API which I have created in dataminer to retrieve the information.
Thijs Vanovenacker [SLC] [DevOps Advocate] Selected answer as best 2nd April 2025
Thijs Vanovenacker [SLC] [DevOps Advocate]2.71K Posted 24th December 2024 9 Comments
Hi Apurva,
Can you please double check if the latest DxMs are installed for:
  • DataAggregator DxM
  • DataAPI DxM
To check/update the DxMs, please navigate to: https://admin.dataminer.services/
Select your system of interest, and navigate on the DxMs tab.
Both DxMs are required for the DataAPI feature to work according to the docs: DataAPI - soft-launch options | DataMiner Docs
Hope this helps!
Vasco Marcelino [SLC] [DevOps Member] Edited comment 2nd April 2025
Thijs Vanovenacker [SLC] [DevOps Advocate] commented 24th December 2024
After doing these steps, I believe you might also need a Cube disconnect. Just log-out & log-in again for the module to show up.
Apurva Tandon [DevOps Member] commented 24th December 2024
Yes its already installed, still doesnt shows up unfortunately after logging in and logging out too.
Bram Devlaminck [SLC] [DevOps Advocate] commented 24th December 2024
Could you try upgrading the Data Aggregator DxM?
There have been patches to both the Data API and Data Aggregator DxM.
Hope this fixes your problem.
I have upgraded both of them to latest version, but still I cannot see Data Sources module and also the datasource I have created
Thijs Vanovenacker [SLC] [DevOps Advocate] commented 2nd January 2025
Hi Apurva, if the DxM is installed, you should also be able to reach the config page directly on the local DataMiner server by navigating in a web-browser to following url: http://localhost/module/data-sources/
Can you confirm if that works? If not, can you tell us what version shows as "installed" under the DxMs page of your setup if you navigate onto
https://admin.dataminer.services/ ? (specifically interested in DxM version for DataAggregator & DataAPI). Thanks
Show 4 more comments
