DataMiner solution available for supply chain management use cases?
Solved561 views5th November 2025#supplychain management
KinetiMinds Tech [DevOps Advocate]218 30th June 2025 0 Comments
Is there any DataMiner solution available for supply chain management use cases?
Dean Muzicka [SLC] [DevOps Catalyst]123 Posted 15th September 2025 0 Comments
Hi KinetiMinds Tech,
Yes, DataMiner as a platform fully supports complex supply chain operations, from logistics and warehousing to energy, fleet management, cargo tracking, and predictive maintenance. It unifies data across IT, OT, and IoT into one operational layer, making processes easier to monitor, automate, and optimize.
Some dedicated supply chain use cases will also be available in the Demo Catalog very soon.
If you’d like, we can arrange a short session to walk you through how the platform can address your specific needs and outline a blueprint for getting started.
https://skyline.be/solutions/smart-ecosystems/book-demo/
