Dataminer Integration Studio URLs required for functionality
Solved213 views24th February 2026
Andrew Teoh [DevOps Member]220 24th February 2026 0 Comments
The system that I have DIS installed on has restricted Internet access. Can I ask what are the domain names or URLs that I need to whitelist to use DIS?
Thanks!
Andrew Teoh [DevOps Member] Selected answer as best 24th February 2026
Miguel Obregon [SLC] [DevOps Catalyst]22.42K Posted 24th February 2026 1 Comment
Hi Andrew,
You can find this information in DataMiner Docs (Prerequisites Communication).
Hope it helps.
Andrew Teoh [DevOps Member] commented 24th February 2026
This is the information I'm looking for. Thanks for pointing me in the right direction.
