Dataminer Cube not connecting to DMA after installing DataMiner integration studio (DIS)
Solved2.43K views28th May 2024dataminer connection DataMiner Integration Studio DIS
Khalid Al-Mahmoodi [DevOps Member]58 24th October 2023 2 Comments
Hi
Dataminer Cube not connecting to DMA after I install DataMiner integration studio (DIS).
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th May 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 26th January 2024
I see that this question has been inactive for some time. Have you found a solution for this yet? If yes, could you select the best answer (using the ✓ icon)? If no, could you let us know what happened when you tried the proposed solutions?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th May 2024
As this question has been inactive for a long time, we will now close it. If you want further assistance, feel free to post a new question or contact techsupport@skyline.be.
Vikas Choudhary [DevOps Member]576 Posted 26th October 2023 0 Comments
Some time windows defender firewall blocked connection. Please either allow public network or add in inbound Firewall Rule for DataMiner cube app.
also if you are using Ziine dataminer demo system, this error comes if it’s down or have huge traffic. I had this problem with Ziine server and it was got resolved once restarted.
Thanks
Vikas Choudhary [DevOps Member] Edited answer 26th October 2023
