DataMiner Cube – Filter table entries using the filter box
Solved1.52K views1st February 2024Cube datamine cube table
Daniela Oliveira [SLC] [DevOps Member]356 25th January 2024 0 Comments
How can I filter entries from a table using the native filter box ?
Please see screenshot where:
I want to see all rows with ‘Other Info’ column = ‘Any’ AND CP = ‘Any’ for example.
Daniela Oliveira [SLC] [DevOps Member] Selected answer as best 1st February 2024
João Severino [SLC] [DevOps Enabler]14.48K Posted 25th January 2024 3 Comments
Hi Daniela,
You should be able to do such a query with a filter like
“Other Info”: “Any” “CP”: “Any”
The result should be something like below
First filter
Adding the second part of the filter
Daniela Oliveira [SLC] [DevOps Member] commented 25th January 2024
Hi João, it worked! Thanks!
Are you aware if there’s any documentation? Or if any other syntax is supported? If I’d like to perform an ‘OR’ instead of an ‘AND’ for example how would it look like?
João Severino [SLC] [DevOps Enabler] commented 25th January 2024
I am not aware of documentation specific to the table filter on the element card but in the past, I have used with success some of the filter types mentioned on this docs page
https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/reference/Dynamic_table_filter_syntax.html
Vasco Marcelino [SLC] [DevOps Member] commented 25th January 2024
Hi Daniela,
In addition to my colleague’s suggestion, you can also extend your filtering to numeric columns of partial tables as it is supported now.
More info in https://docs.dataminer.services/release-notes/Cube/Cube_Feature_Release_10.4/Cube_10.4.3.html?q=ID_38367#enhanced-operator-support-when-constructing-filters-for-numeric-columns-of-partial-tables-id_38367
