Dataminer Cube Connection Issue Following 10.3 Upgrade
Solved3.51K views25th January 2024Cube connect Cube Logging DataMiner Cube
Tony White [DevOps Enabler]18 11th October 2023 0 Comments
Hi Community
I have a brand-new DMA running on Win11 laptop as a demo. It was initially installed as version 10.2 and worked. Following upgrade to 10.3, and beyond the Cube client updating itself on the first attempt to connect, I can no longer connect via DM Cube application either locally or remotely.
Message in Cube GUI is:
"Connection timeout. The DataMiner agent did not respond in time."
Cube log reads as follows (captures several login attempts):
2023-10-11 16:31:06.783|PID:12004 [INF] General: Main window closing.
2023-10-11 16:31:06.924|PID:12004 [INF] RunModeManager: Entering mode: ShuttingDown
2023-10-11 16:31:06.924|PID:12004 [INF] General: Checking if a save is queued, before shutdown...
2023-10-11 16:31:06.924|PID:12004 [INF] General: Checking for uncompleted file operations, before shutdown...
2023-10-11 16:31:07.002|PID:12004 [INF] General: Exiting instance.
2023-10-11 16:32:34.834|PID:12872 [INF] General: Product version: 10.3.2246.490-48cc672f
2023-10-11 16:32:35.818|PID:12872 [INF] General: Launched exe: C:\Users\USER\AppData\Local\Skyline\DataMiner\DataMinerCube\DataMinerCube.exe with arguments: /Autorun
2023-10-11 16:32:35.818|PID:12872 [INF] General: Launcher version: 10.3.2246.490-48cc672f
2023-10-11 16:32:36.536|PID:12872 [INF] RunModeManager: Launch arguments after PrepareLaunchArguments: /Autorun
2023-10-11 16:32:40.492|PID:12872 [INF] RunModeManager: Entering mode: Systray
2023-10-11 16:32:40.632|PID:12872 [INF] General: Pre-loading UI...
2023-10-11 16:32:45.002|PID:12872 [INF] General: The launcher config file has been externally changed: C:\Users\USER\AppData\Local\Skyline\DataMiner\DataMinerCube\CubeLauncherConfig.json Changed
2023-10-11 16:32:45.004|PID:12872 [INF] General: The launcher config file has been externally changed: C:\Users\USER\AppData\Local\Skyline\DataMiner\DataMinerCube\CubeLauncherConfig.json Changed
2023-10-11 16:51:33.220|PID:12872 [INF] Launcher Update: Local launcher version: 10.3.2246.490
2023-10-11 16:51:33.226|PID:12872 [INF] Launcher Update: Checking latest version on server localhost
2023-10-11 16:51:33.235|PID:12872 [INF] Launcher Update: Checking version info on localhost over "HTTP"
2023-10-11 16:51:33.375|PID:12872 [INF] Launcher Update: Latest launcher version on localhost: 10.3.2243.4486
2023-10-11 16:51:33.375|PID:12872 [INF] Launcher Update: No launcher update needed
2023-10-11 16:51:33.383|PID:12872 [INF] DMSCommunicator: Trying to retrieve server version from http://localhost/DataMinerCubeStandalone/VersionInfo.ashx...
2023-10-11 16:51:33.955|PID:12872 [INF] ClickTwice: Getting available versions on localhost
2023-10-11 16:51:33.957|PID:12872 [INF] ClickTwice: Skipping Cloud Version Manager as internet communication is not allowed in this stage.
2023-10-11 16:51:33.960|PID:12872 [INF] DMARemoteVersionManager: Checking available versions on server localhost
2023-10-11 16:51:34.012|PID:12872 [INF] ClickTwice: Launching version 10.3.2335.2420 with arguments host=localhost alias=localhost screen=\\.\DISPLAY1 cubelauncher="C:\Users\USER\AppData\Local\Skyline\DataMiner\DataMinerCube\DataMinerCube.exe"
2023-10-11 16:51:34.075|PID:12872 [INF] ClickTwice: Launched process ID: 3644
2023-10-11 16:51:34.081|PID:12872 [INF] General: Main window closing.
2023-10-11 16:51:34.405|PID:3644 [INF] General: Product version: 10.3.2246.490-48cc672f
2023-10-11 16:51:34.439|PID:3644 [INF] RunModeManager: Entering mode: Hosting
2023-10-11 16:51:39.775|PID:3644 [WRN] CubeHost: Unable to load assembly "Grpc.Net.Client.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=d754f35622e28bad": file does not exist (C:\Users\USER\AppData\Local\Skyline\DataMiner\DataMinerCube\DataMiner Cube\Versions\10.3.2335.2420\Grpc.Net.Client.Web.dll)
2023-10-11 17:11:22.759|PID:12872 [INF] General: Explicit updates check for launcher and Cube...
2023-10-11 17:11:22.765|PID:12872 [INF] BackgroundUpdater: Running version: 10.3.2246.490
2023-10-11 17:11:22.775|PID:12872 [INF] BackgroundUpdater: Selected update track: Release
2023-10-11 17:11:22.775|PID:12872 [INF] BackgroundUpdater: Checking for updates of Cube launcher on dataminer.services on track Release
2023-10-11 17:11:22.775|PID:12872 [INF] Launcher Update: Checking version info on dataminer.services over "HTTPS"
2023-10-11 17:11:24.010|PID:12872 [INF] BackgroundUpdater: Latest version on dataminer.services: 10.3.2246.490
2023-10-11 17:11:24.025|PID:12872 [INF] BackgroundUpdater: Starting background update for 1 clusters. Allow contacting DMA's: False
2023-10-11 17:11:24.025|PID:12872 [INF] BackgroundUpdater: Last known server version for localhost: 10.3.0.0-13374. For this update, we assume this hasn't changed.
2023-10-11 17:11:24.025|PID:12872 [INF] CloudCommunicator: Requesting versions of track Delayed 342349044...
2023-10-11 17:11:25.510|PID:12872 [INF] CloudCommunicator: Received versions on Delayed 342349044 in 1471 ms.
2023-10-11 17:11:25.526|PID:12872 [INF] BackgroundUpdater: Checking version for hostname localhost
2023-10-11 17:11:25.526|PID:12872 [INF] ClickTwice: Preparing for downloading version for server localhost
2023-10-11 17:11:25.526|PID:12872 [INF] ClickTwice: Best version for localhost according to Cloud Version Manager: 10.3.2335.2420
2023-10-11 17:11:25.541|PID:12872 [INF] ClickTwice: 10.3.2335.2420 available in local cache. No download necessary.
2023-10-11 17:11:25.541|PID:12872 [INF] ClickTwice: Updating revoked versions...
2023-10-11 17:11:25.557|PID:12872 [INF] BackgroundUpdater: Background update completed
2023-10-11 17:11:25.557|PID:12872 [INF] General: 0 new Cube versions downloaded.
2023-10-11 17:14:35.620|PID:12872 [INF] Launcher Update: Local launcher version: 10.3.2246.490
2023-10-11 17:14:35.620|PID:12872 [INF] Launcher Update: Checking latest version on server localhost
2023-10-11 17:14:35.620|PID:12872 [INF] Launcher Update: Checking version info on localhost over "HTTP"
2023-10-11 17:14:35.632|PID:12872 [INF] Launcher Update: Latest launcher version on localhost: 10.3.2243.4486
2023-10-11 17:14:35.632|PID:12872 [INF] Launcher Update: No launcher update needed
2023-10-11 17:14:35.633|PID:12872 [INF] DMSCommunicator: Trying to retrieve server version from http://localhost/DataMinerCubeStandalone/VersionInfo.ashx...
2023-10-11 17:14:35.637|PID:12872 [INF] ClickTwice: Getting available versions on localhost
2023-10-11 17:14:35.637|PID:12872 [INF] ClickTwice: Skipping Cloud Version Manager as internet communication is not allowed in this stage.
2023-10-11 17:14:35.637|PID:12872 [INF] DMARemoteVersionManager: Checking available versions on server localhost
2023-10-11 17:14:35.638|PID:12872 [INF] ClickTwice: Launching version 10.3.2335.2420 with arguments host=localhost alias=localhost screen=\\.\DISPLAY1 cubelauncher="C:\Users\USER\AppData\Local\Skyline\DataMiner\DataMinerCube\DataMinerCube.exe"
2023-10-11 17:14:35.659|PID:12872 [INF] ClickTwice: Launched process ID: 7984
2023-10-11 17:14:35.660|PID:12872 [INF] General: Main window closing.
2023-10-11 17:14:35.899|PID:7984 [INF] General: Product version: 10.3.2246.490-48cc672f
2023-10-11 17:14:35.938|PID:7984 [INF] RunModeManager: Entering mode: Hosting
2023-10-11 17:14:37.923|PID:7984 [WRN] CubeHost: Unable to load assembly "Grpc.Net.Client.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=d754f35622e28bad": file does not exist (C:\Users\USER\AppData\Local\Skyline\DataMiner\DataMinerCube\DataMiner Cube\Versions\10.3.2335.2420\Grpc.Net.Client.Web.dll)
Any advice as to how to further diagnose or rectify this issue would be much appreciated, please.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 25th January 2024
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 25th January 2024 0 Comments
As this question has been open for some time, and this looks like an issue that will require an in-depth investigation beyond the scope of the Q&A, could you contact techsupport@skyline.be for assistance in case this issue has not been resolved yet? We will close this question here.
