Dataminer Cube and HTTPS communications
Solved2.98K views12th February 2024Cube HTTPS
Phillip Choi56 2nd January 2024 0 Comments
How can you confirm if the cube communicates to the Dataminer using HTTPS other than a Wireshark capture? Are there any indicators within the cube application to show this? Is it normal for me to see POSTS in HTTP?
POST /SLNetService HTTP/1.1
User-Agent: Mozilla/4.0+(compatible; MSIE 6.0; Windows 10.0.19045.0; MS .NET Remoting; MS .NET CLR 4.0.30319.42000 )
Content-Type: application/octet-stream
Host: x.x.x.x:8004
Content-Length: 1042
........................HandleMessages.kSkyline.DataMiner.Net.ISLNet, SLNetTypes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9789b1eac4cb1b12......... .... .........MSLNetTypes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9789b1eac4cb1b12......Skyline.DataMiner.Net.Security.ConnectionToken....
_connectionID._token._seqID....System.Guid............System.Guid....._a._b._c._d._e._f._g._h._i._j._k.......................f..P9.@.Z}$.<.. .......................)Skyline.DataMiner.Net.Messages.DMSMessage.... ...............M.......5Skyline.DataMiner.Net.Messages.Advanced.ZippedMessage....
ZippedData...... ..............PK........
V"X._.-1...........data.RMK.@.M....M<.!7)...A
$.4.ES..^D.&.JH.-......;m...........[f.UQ./i....d.....I...7_......9..7..\....JQ..o..(O...&...k......_...Y...[.]..Y....G.... ....s:.N<?..(...A.0...y.P.O...C.3^gtY{......,.oi..lz.B..:.n....D....<v.)c.,{.Nj..j.[*G=....u+ i.{.._........G.N.x.y a.......H.mT7i.;.......5.`...4.dC~d...@...PK..3.......
V"X._.-1.........................dataPK..........2...S.....
Nils Hoven [DevOps Advocate] Answered question 12th February 2024
João Severino [SLC] [DevOps Enabler]14.78K Posted 2nd January 2024 1 Comment
Hi Phillip,
From the Wireshark capture snippet you showed it does look like the communication is using HTTP and the port and service being used are consistent with SLNet communication.
As part of the DataMiner hardening guide, one step mentions a few BPAs that can automatically verify if your system is as secure as possible. One that could be useful in your case is the HTTPS one (see HTTPS Configuration | DataMiner Docs).
The links above also provide you with some information in case you see it necessary and wish to better secure your system.
Phillip Choi Posted new comment 2nd January 2024
Phillip Choi commented 2nd January 2024
Thanks. Unfortunately, we are on 10.1 and the BPAs are only from 10.3 and up.
