DataMiner changed from running to disconnected.
Solved2.29K views16th March 2023connection DMS
Ryan Reuss [SLC] [DevOps Member]562 3rd November 2021 0 Comments
Hello team,
I was wondering exactly what triggers this message. I have set up connection strings to and from all the DMAs in the cluster and this pop-up occurs quite frequently.
Ryan Reuss [SLC] [DevOps Member] Selected answer as best 16th March 2023
Brent Alleweireldt [SLC]2.74K Posted 3rd November 2021 0 Comments
Hey Ryan,
These pop up boxes get thrown based on the DataMinerExtendedStateEvent sent by server to the client. These events contain the info on the state and the reason for the change.
The disconnected state gets thrown when the connection between dma agents is refused or destroyed. Losing connections can happen for a lot of reasons. When a connection gets destroyed (and the message thrown) the reason for the disconnect should be logged in the SLNet-Logging. Look for "Closing DMA Connection"
