DataMiner Application Framework – run interactive automation script
Solved3.02K views29th June 2022Application Framework DataMiner Application Framework interactive automation script
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 29th June 2022 0 Comments
Is there a way to run interactive automation scripts from a custom application?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 29th June 2022
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K Posted 29th June 2022 0 Comments
Yes, there are 2 ways of doing so.
Through the header bar
Enable the application header bar and add a new header option (+ sign).
Add an ‘On click’ event and choose your Automation script
Through a button component
Add a component of type ‘Button’, and link it with your Automation script through its ‘Settings’ menu via an ‘On click’ event. You might need the ‘ReportsAndDashboardsButton’ soft-launch option.
Interesting to note is that you can pass data to the script input parameters in a fixed way, or via feeds.
