DataMiner Alarms Capacity – alarms per second
Solved3.21K views11th July 2023alarm storm alarms
8
João Santos [SLC]40 16th November 2020 0 Comments
How many alarms (per second) can a DataMiner system handle?
It is known and available on DataMiner help the amount of concurrent active alarms that a DataMiner Agent and a DataMiner system can handle. It is also available on DataMiner help, information about the Alarm storm protection, and how to configure it.
Although, the question here is tied with the alarming rate on a DataMiner Agent. Is there any mechanism available to predict how many alarms we can ingest in a DMA (DataMiner Agent)? Worth to be mentioned that the system resources might have a direct impact on such capability.
Alexander Verriest [SLC] [DevOps Advocate]754 Posted 20th November 2020 0 Comments
We have an internal tool that generates an increasing amount of alarms/s until we see that the queues can't handle the load anymore (we only measure on Cassandra at this point though). Afterwards the results are returned to the user. The alarms generated are "lightweight", so do not contain alarm properties etc., so we get a theoretical "maximum" rate at which alarms can be generated without anything blowing up.
On a i7 2.6Ghz, 32GB ram, 64-bit operating system we saw we could generate around 240 alarms/s this way.
Note that it is perfectly fine to generate alarms at a higher rate, as long as it is temporary. This numger only gives the theoretical maximum rate at which alarms can be created continuously.
We use this number to check for regression on our system. I.e, to check if the rate at which we can generate and process alarms does not go down over time when changes are made to the code. We do not care about the value itself, only about evolution over time.
This tool is for now only used within Dodo squad, but we plan on making it public in the future, so you'd be able to check this rate on your own machine.
