DataMiner AI relationship with Cassandra and Elastic DB
Solved2.51K views7th July 2023AI Cassandra Elastic
11
Naveendran Murthy [SLC] [DevOps Member]226 22nd February 2023 0 Comments
Does DataMiner AI require both Cassandra and Elastic DB to unlock all of its functionalities? Or would all of the functionalities work with just Cassandra DB alone?
Willem Mélange [SLC] [DevOps Member]298 Posted 22nd February 2023 0 Comments
Only the pattern matching feature needs Elastic. This will not work without it.
Behavioral Anomaly detection is a bit special in that regard. It will work without Elastic. However, you will need it to be able to query the datasource in Dashboards.
Karel Lodefier [SLC] [DevOps Member]724 Posted 22nd February 2023 1 Comment
Hi Naveen, please find here the link of features requiring Cassandra & Elasticsearch: Data Storage Architecture – DataMiner Dojo
Pieter Van Compernolle [SLC] [DevOps Enabler] Posted new comment 22nd February 2023
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 22nd February 2023
not sure if that page is up to date with the latest release info Karel.
Srikanth Mandava [SLC] [DevOps Advocate]936 Posted 22nd February 2023 0 Comments
Naveen
Please note that we no longer recommend any production deployments with Cassandra database only; please refer to Supported system data storage architectures | DataMiner Docs .
However, you can install Elasticsearch and Cassandra in one node as the bare minimum; please see the following section at DataMiner Compute Requirements – DataMiner Dojo .
“Important: If you intend to run, e.g. DataMiner, Cassandra and Elasticsearch on a single server, the hardware requirements in the diagram below need to be added up. So, when it comes to RAM, in this case you would need a minimum of 96 GB (32 GB for DataMiner, 32 GB for Cassandra and 32 GB for Elasticsearch).”
Going back to your original question,
From my understanding AI features are referred to as ‘Advanced Analytics’ in our documentation. As Willem confirmed above, only the pattern matching feature requires Elasticsearch, and the rest works with the Cassandra database. The following links summarise features and their dependency on the relevant database.
Advanced analytics in trend graphs | DataMiner Docs
Advanced analytics features in the Alarm Console | DataMiner Docs
Thanks
Srikanth Mandava [SLC] [DevOps Advocate] Answered question 22nd February 2023
