Data Sources element not showing any data
Solved1.79K views8th January 2025#datasources #scripted connector Data API
Apurva Tandon [DevOps Member]1.73K 7th January 2025 0 Comments
I have datasources script in python which runs fine and also I can see the element also got created, but when I click on that element it shows that no visible data pages available.
in http://localhost:34567/swagger/index.html when test on api/parameters I see that I get “Sequence contains no element” what can be the reason?
Apurva Tandon [DevOps Member] Selected answer as best 8th January 2025
João Severino [SLC] [DevOps Enabler]14.78K Posted 8th January 2025 0 Comments
Hi Apurva,
With DataAPI, an array symbolizes a table. If you have an array inside another array, we try to create a linked table with a foreign key relationship. This means that the “ServiceInvolved” property in your JSON would be a linked table, but because it does not have a key-value pair structure, it fails to resolve the parameter structure.
I did a quick local test and with your JSON I got the same error but if I adapt it not to include the “ServiceInvolved” property
“components”: [{
“AlarmId”: 3614501,
“ElementId”: 290,
“ElementName”: “Sky-News-TXCore”,
“Severity”: “Critical”,
“ParameterDescription”: “Memory Usage (Servers Info) sky-news-pi-ams”,
“ParameterValue”: “70.000000”,
“StartTime”: “/Date(1736263098000)/”,
“ClusterName”: “Contribution”
“AlarmId”: 3614481,
“ElementId”: 312,
“ElementName”: “MUN-X20-FRM-003_1_2_4_19”,
“ParameterDescription”: “Signal Loss (Decoder Services) 3/Auto First Service [239.202.1.4:5000] 3G-1BD”,
“ParameterValue”: “BLACK_FRAME”,
“StartTime”: “/Date(1736262135000)/”,
I get it to work with the following result
If you still want to keep the “ServiceInvolved” property I would suggest adapting the structure to be something more like
“components”: [{
“AlarmId”: 3614501,
“ElementId”: 290,
“ServiceInvolved”: “TX Core”,
“AlarmId”: 3614481,
“ElementId”: 312,
“ServiceInvolved”: “”,
And you would get something like
José Silva [SLC] [DevOps Enabler]2.11K Posted 8th January 2025 1 Comment
Hi Apurva,
I’m not sure if this will help with your debugging, but the error "Sequence contains no element" typically occurs when LINQ methods like .First(), .Single(), etc., are used on a collection that is either empty or null. These methods assume the collection contains at least one element and will throw this error if none are found.
To avoid this, it’s better to use .FirstOrDefault() or .SingleOrDefault(). These methods return null when no elements are present, allowing you to handle such cases more gracefully. After retrieving the result, you can add a check to see if it’s null or empty before proceeding with the logic.
Using this approach can help ensure your code is more robust and avoids unexpected exceptions when dealing with empty collections.
Apurva Tandon [DevOps Member] Posted new comment 8th January 2025
Apurva Tandon [DevOps Member] commented 8th January 2025
In API on swagger I pass this type of JSON and still get Sequence contains no element cant figure out what issue
{ "components": [
"AlarmId": 3614501,
"ElementId": 290,
"ElementName": "Sky-News-TXCore",
"Severity": "Critical",
"ParameterDescription": "Memory Usage (Servers Info) sky-news-pi-ams",
"ParameterValue": "70.000000",
"StartTime": "/Date(1736263098000)/",
"ServiceInvolved": [
"TX Core"
"ClusterName": "Contribution"
"AlarmId": 3614481,
"ElementId": 312,
"ElementName": "MUN-X20-FRM-003_1_2_4_19",
"ParameterDescription": "Signal Loss (Decoder Services) 3/Auto First Service [239.202.1.4:5000] 3G-1BD",
"ParameterValue": "BLACK_FRAME",
"StartTime": "/Date(1736262135000)/",
