Dashboards: renaming numerical column and fixing the number for the Top X
Solved1.50K views26th June 2024Dashboard and Query
Yahya Mesmoudi [DevOps Member]319 25th June 2024 0 Comments
Hi Dojo team,
I have two questions on Dashboards:
  1. Is it possible to rename or duplicate a numerical column and keep it as numerical?
  2. Is there a way to define the exact number for the Top X outside of the query, such as in a dropdown component?
Thank you!
Yahya Mesmoudi [DevOps Member] Selected answer as best 26th June 2024
Wout Mahieu [SLC] [DevOps Catalyst]12.45K Posted 25th June 2024 2 Comments
Hi Yahya,
  1. There is a ‘Rename column‘ custom operator available on the catalog that can be used for this. An other option would be to rename the column using a ‘concatenate’ column manipulation with only that column. Afterwards you would have to use the ‘Parse number‘ operator to parse it back to a number.
  2. No, there is currently no way to feed a value to to the ‘X’ of the Top X operator. I have created a task for us to implement this.
Yahya Mesmoudi [DevOps Member] commented 25th June 2024
Thank you, Wout, for the answer elements.
In my particular case, I am unable to proceed because the DMA I am using is not on the Skyline Cloud, which prevents me from deploying anything from the catalog.
Wout Mahieu [SLC] [DevOps Catalyst] commented 26th June 2024
That is no problem, the source code for both operators is also available on our github (https://github.com/SkylineCommunications/SLC-GQIO-RenameColumn & https://github.com/SkylineCommunications/SLC-GQIO-ParseNumber). You can add these script manually to your DMS.
