Dashboards – Node Edge Graph – inherit the severity colors of its parameters
Solved1.21K views12th September 2025Dashboard Graph Node edge graph remove dashboards severity colors
Guy Lavee [DevOps Member]128 26th May 2025 0 Comments
Hey,
We created a dashboard using: "Node Edge Graph" to visualize the state of the network.
We would like the "Nodes" and "Lines" in the generated graph (See snapshot below) to inherit the colors of the parameters that it is representing.
Today using this dashboard the operators need to click on each Node \ Line to see if there are any errors \ alerts on it.
Thank you.
Stephen Lanszweert [SLC] [DevOps Member]199 Posted 26th May 2025 1 Comment
Hi Guy,
Thanks for your question.
When you hover over a node or an edge in the graph, you’ll see an option in the top right corner to configure the color.
There are three available color modes:
  • Static: a fixed color.
  • Analytical: lets you define colors based on specific values.
  • Alarm: automatically sets the color based on the highest severity level among all values associated with that node or edge.
In this use case, I would recommend using the alarm mode since this will automatically show the highest severity color.
Hope this helps! Let us know if you need further assistance.
Guy Lavee [DevOps Member] Posted new comment 26th May 2025
Guy Lavee [DevOps Member] commented 26th May 2025
Perfect. That is exactly what we were looking for.
Thank you for your help.
