Dashboards – frequently changing parameters are not readable (too many datapoints)
Solved1.77K views4th October 2021Dashboard App Dashboards trending
Alexander Gorbunov [SLC] [DevOps Advocate]1.20K 4th October 2021 0 Comments
I have difficulties displaying frequently changing parameters in Dashboards, both new and the legacy version. The problem is that with 5-minute average trending available, there are too many datapoints, and the resulting plot looks like a solid filled area. This gets even worse if I plot several parameters in one graph. See examples:
As you can see, when 5-minute datapoints expire and only 1-hour average data is present, the graphs are much clearer.
So the question is, is there a way to force Dashboard (old or new app) to use only 1-hour datapoints? Or are there other ways you could recommend to make these graphs more readable?
Thanks.
Alexander Gorbunov [SLC] [DevOps Advocate] Selected answer as best 4th October 2021
Wim Bruynooghe [SLC] [DevOps Advocate]6.78K Posted 4th October 2021 0 Comments
At the moment it’s not possible to configure this in Dashboards. However, it will automatically take 5-minute records or 60-minute records, depending on:
  • the selected timespan, it will use 60-minute records if the timespan is 48 hours or more, otherwise 5-minute records
  • which points there are available in the database (see trending settings in maintenancesettings.xml)
The result you get is not expected so this might be a software issue.
