Dashboard – Switching Inputs on DEV1953 with changing mode from auto to remote.
Solved2.33K views11th July 2024dashboard button dev1953 MIB
Adrian Marcak158 28th June 2024 1 Comment
I managed to configure the DEV1953 button on the dashboard, which allows you to configure InputA/B:
For this to make sense, the next step is to control the switch mode, which is set to auto by default. From the DMA level we can't control the parameter. We can only display it without changing it. Using Mibbrowser I managed to change the mode. The question is whether it would be possible to combine these two things into one button and, each time you try to change the input, switch the mode from auto to remote and restore the setting after changing it. Alternatively, make a separate button to change the mode on the dashboard.
BR,
Adrian
Adrian Marcak Selected answer as best 11th July 2024
Felix Wesemeier [DevOps Catalyst] commented 28th June 2024
Which protocol are you using?
The DEV Switch SNMP for example has this parameter integrated with read/write.
Adrian Marcak158 Posted 9th July 2024 2 Comments
Thank you,
I changed protocol to DEV Switch and now it is possible to change ControlMode from DMA:
however, I am having trouble creating buttons for this configuration from the Dashboard. ControlMode itself reads as a parameter this way:
but when I try to configure the buttons to appear depending on the current Switch setting, none of them appear. Therefore, I do not know whether the Execute configuration is correct or whether it causes the lack of visibility of these buttons:
Could you tell me what I'm doing wrong?
BR,
Adrian
Adrian Marcak Posted new comment 11th July 2024
Miguel Obregon [SLC] [DevOps Catalyst] commented 10th July 2024
Hi Adrian,
Sorry, I overlooked your message.
I had a look at the screenshots and I noticed that you are using the element name in the ‘Set’ data shape. Instead of the element name, you should use the element ID
https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/linking_shapes/Linking_a_shape_to_a_SET_command.html
Apart from that, I believe you don’t need the ‘Enabled’ data shape.
Can you try these changes and let us know the outcome?
Adrian Marcak commented 11th July 2024
Thank you Miguel,
now the buttons work as they should.
