Dashboard – How to link to another dashboard in a system with MFA
Solved1.37K views17th January 2023Dashboard Multi-Factor Authentication
Jens Vandewalle [SLC] [DevOps Advocate]9.85K 11th August 2022 0 Comments
In a system with MFA enabled I want to add a link to another Dashboard. This is configured by using a web component with the full URL of the dashboard, but this doesn't seem to work when MFA is enabled. Is there another way?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 17th January 2023
Gilles Bara [SLC] [DevOps Advocate]7.17K Posted 12th August 2022 1 Comment
The webpage component is sandboxed to only allow content from the same origin. Because MFA requires a source from an external party, it will be blocked off.
Feel free to create a task on Collaboration to get this functionality added.
Jens Vandewalle [SLC] [DevOps Advocate] commented 16th August 2022
Thank you, Gilles. Task created
