Dashboard GQI “Filter” issue on a table and a specific parameter column.
Solved1.79K views8th July 2021Dashboard filter GQI
Randy Ulvenes [SLC] [DevOps Member]1.31K 8th July 2021 0 Comments
I created a query to filter on all cisco switch port IF Utilization bandwidth above 1 MBPS.   As can be seen in the image, all ports are included.  I tried the same filter on the IF Utilization % and had the same result.
I attached a screenshot of the query and results.
I am running 10.7.1 but noticed the same results on 10.6.1.
Randy Ulvenes [SLC] [DevOps Member] Selected answer as best 8th July 2021
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 8th July 2021 0 Comments
Hi Randy,
We have identified a similar issue as well. The filter is only applied on the first 2 elements of the configured protocol. This should be resolved with RN30187 which is included in the next 10.1.8 release.
