Dashboard difficulties combining parameter alarms with grid components
188 views13th March 2026Dashboard get Alarms GQI queries
Mathew Hyland [DevOps Advocate]136 13th March 2026 0 Comments
Hi Dojo
I'm trying to create a dashboard using a grid component I want to use the parameter alarm state as well as the value, I\'ve created this query with a join to the get alarms for CPU and MEM usage, however alarms seems to be at the element level and not the parameter.
Any assistance would be appreciated, thanks
Miguel Obregon [SLC] [DevOps Catalyst] Answered question 13th March 2026
Miguel Obregon [SLC] [DevOps Catalyst]22.39K Posted 13th March 2026 2 Comments
Hi Mathew,
Is it required for your use case to use a grid component?
Is it not an option to use state/gauge components? For example, have a look at the screenshot available in the landing page of the Microsoft Platform connector. For this dashboard we used gauge components.
Hope it helps.
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 15th March 2026
Mathew Hyland [DevOps Advocate] commented 13th March 2026
Hi Miguel
Thanks for your reply, the original dashboard was made up of the rings, as we used this to monitor the DMAs there are quite a few elements and the grid component seemed the best approach. As it was viewed from a distance I also wanted to be able change the ring labels to something more visible.
thanks
Mathew
Miguel Obregon [SLC] [DevOps Catalyst] commented 15th March 2026
When using the grid components, you could set the color of the background based on the value of the metric. See template editor (conditions):
https://docs.dataminer.services/dataminer/Functions/Dashboards_and_Low_Code_Apps/Configuring_components/Template_Editor.html?tabs=gridtabid-1#adding-conditional-cases-to-a-layer
