Dashboard – component does not scale vertically
Solved624 views29th May 2025
Miloš Sedláček [DevOps Advocate]702 28th May 2025 0 Comments
Dear Madam/Sir,
I'm using a Column & bar chart in my dashboard. While it scales well in horizontal direction - making the component narrower or wider adapts the chart, it doesn't scale well in vertical direction.
Making the component lower or higher does not adopt the height of the columns/charts in it and one should scroll inside the component. This is particularly inconvenient in case multiple components must be placed in the dashboard so the height of the component must be decreased and therefore one should scroll in it. An example below:
Miloš Sedláček [DevOps Advocate] Selected answer as best 29th May 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.54K Posted 28th May 2025 1 Comment
Hi Miloš,
This is not expected behavior, the bar chart component should adapt its viewport to its size. You should not see any scrollbars when resizing the component. Can you contact tech support (techsupport@skyline.be) so that we can look further into this issue?
Miloš Sedláček [DevOps Advocate] Posted new comment 29th May 2025
Miloš Sedláček [DevOps Advocate] commented 29th May 2025
Hi Wout,
I made a DMA reboot (from another reason) and the scaling works fine now.
Thanks.
