DaaS system mirroring the live system
400 views2 days agoconfiguration DaaS Production
Curtis Baiden [DevOps Advocate]574 4th November 2025 1 Comment
Can a DaaS system mirroring the live system will hold the last known alarms if we lose production
Marieke Goethals [SLC] [DevOps Catalyst] Answered question 2 days ago
Wouter Bogaert [SLC] [DevOps Enabler] commented 14th November 2025
Hi Curtis, thanks for your interest in DaaS. Can you elaborate a bit more on your question? It is unclear to me what setup you are describing and what exactly you are looking for. Thanks.
Marieke Goethals [SLC] [DevOps Catalyst]7.33K Posted 2 days ago 0 Comments
I noticed that this question has been open for some time now. Do you still need help with this? If yes, could you elaborate a bit on your question, as Wouter asked earlier? Or if if you no longer need this information, could you select this answer to indicate that no further follow-up is required?
