Customize Tooltip in Node Edge Graph
Solved1.36K views13th February 2025LCA node-edge
Thomas Remmery [SLC] [DevOps Advocate]957 13th February 2025 0 Comments
Is it possible to customize the tooltip displayed when hovering over a Node in Node Edge Graph? In my case, I would like to remove some fields.
Thomas Remmery [SLC] [DevOps Advocate] Selected answer as best 13th February 2025
Michiel Saelen [SLC] [DevOps Advocate]6.34K Posted 13th February 2025 0 Comments
You can drag the columns from the query towards the filter of your component.
Michiel Saelen [SLC] [DevOps Advocate] Edited answer 13th February 2025
