Customize Tooltip in Node Edge Graph
Solved2.05K views13th February 2025LCA node-edge
Thomas Remmery [SLC] [DevOps Advocate]1.06K 13th February 2025 0 Comments
Is it possible to customize the tooltip displayed when hovering over a Node in Node Edge Graph? In my case, I would like to remove some fields.
Thomas Remmery [SLC] [DevOps Advocate] Selected answer as best 13th February 2025
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 13th February 2025 0 Comments
Hi Thomas,
You can drag the fields from your query, as a filter onto your node-edge graph.
