Cube tests script for views
325 views5th November 2026Automation script Cube Testing views Visio
Ryan Hepworth [DevOps Advocate]1.83K 3rd November 2026 0 Comments
Hi All,
A weird question but I am going to ask it.
Is there a way for us to run a script that will open and close views in cube for load testing purposes to remove the human element of opening and closing?
Thank
Ryan
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 5th November 2026
Pieter Van Compernolle [SLC] [DevOps Enabler]4.59K Posted 5th November 2026 0 Comments
Hi Ryan,
If you're talking about automation scripts, the answer is no, since they run on the agent and not at the client machine.
For UI automation, there are many tools available. Cube is built in WPF and Ranorex is one of the tools we are using. I see they offer free trials.
