Cube System settings plugins web browser engine setting details?
Solved1.99K views18th July 2023
Jeff Douglass870 21st June 2021 0 Comments
Can someone explain exactly what this setting does and what it affects? Items such as:
  1. Does this affect how the Stand Alone cube client interfaces to the DM agent
  2. Does this affect how the Stand Alone cube client interfaces to DM agent modules such as Reports and Dashboards
  3. Does this affect the Web Interface option present in every element's Data page
  4. If this is set to Chromium are any IE Internet settings still needed.
    1. such as trusted sites?
  5. If Chromium is selected does chrome need to be installed or are all the required elements included with the DM installation.
Thanks
Wim Bruynooghe [SLC] [DevOps Advocate]6.78K Posted 22nd June 2021 0 Comments
  1. No
  2. Yes, it impacts all web modules like Reports and Dashboards, Ticketing, etc.
  3. Yes, exceptions can be configured per protocol.
  4. No
  5. The Chromium engine is included in the DataMiner installation, so Chrome does not need to be installed separately.
Wim Bruynooghe [SLC] [DevOps Advocate] Answered question 22nd June 2021
