Creating SVGs for use in node-edge graph component
Solved429 views8th September 2025LCA node-edge
Enver Podgorcevic [SLC] [DevOps Advocate]136 4th September 2025 0 Comments
I am trying to combine 2 existing SVG icons from skylicons into one, for use in a node-edge graph component.
I tried doing this in Inkscape, but after exporting and copying the SVG to my DMA, using it in a node-edge graph doesn't show anything visible. There's no even a broken icon image, just a plain empty node.
Is there any recommended way of creating SVGs for use in node-edge graph?
Enver Podgorcevic [SLC] [DevOps Advocate] Selected answer as best 8th September 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.60K Posted 4th September 2025 1 Comment
Hi Enver,
All valid SVG files should work for the component. Does it work with other SVGs when you configure them in the same way? Does the image fetch correctly or do you see the default placeholder?
Edit:
The issue was a badly scaled SVG image. The icon was only 150x150 in the top left of the 90_000x90_000 image. Updating the scaling fixed the issue.
Enver Podgorcevic [SLC] [DevOps Advocate] commented 4th September 2025
Hi Wout! This is a valid SVG, it opens correctly in browsers. The result I get in node-edge graph is just empty space, no broken image icon.
