Creating automation script Problem SDK
Solved1.54K views27th February 2025
Davor Joleski [DevOps Enabler]743 20th February 2025 0 Comments
Hello community i have problem with automation script creating probably SDK is not imported how can i import that or other solutions thanks.
Davor Joleski [DevOps Enabler] Selected answer as best 27th February 2025
Davor Joleski [DevOps Enabler]743 Posted 27th February 2025 0 Comments
DIS: template for Automation and user Defined API not working anymore
This helped me to solve the problem
Thanks.
Davor Joleski [DevOps Enabler] Answered question 27th February 2025
