Creating automation script Problem SDK
Solved2.24K views27th February 2025
Davor Joleski [DevOps Enabler]743 20th February 2025 0 Comments
Hello community i have problem with automation script creating probably SDK is not imported how can i import that or other solutions thanks.
Davor Joleski [DevOps Enabler] Selected answer as best 27th February 2025
Avatar photo
Jan Staelens [SLC] [DevOps Advocate]969 Posted 21st February 2025 5 Comments
Hello,
Could you double check
1. Inside the Terminal (CLI) on your computer.
1. Check if you have *nuget.org* as a known nuget source
dotnet nuget list source
Check that the result contain *nuget.org \[Enabled\]*
Be aware: The first time you run a dotnet command on any computer you'll first get a welcome text. Check below that to see the output of your command.
1. If your sources do not contain *nuget.org* call the following
dotnet nuget add source https://api.nuget.org/v3/index.json -n "nuget.org"
Also, make sure you close all your visual studio instances and then try to create a new automationscript project.
Normally the SDK is available on nuget.org and the last version will be retrieved automatically.
Does that solve the issues you're seeing?
Davor Joleski [DevOps Enabler] Posted new comment 26th February 2025
Davor Joleski [DevOps Enabler] commented 21st February 2025
Hi Jan the nuget org is Enabled but same issue what else can be
i mean ill send picture below what i've checked on welcome page
Avatar photo
Jan Staelens [SLC] [DevOps Advocate] commented 24th February 2025
Hmm, we did manage to recreate your issue but it's not consistent and it was on an older VS2022 version. Could you check if you've got any updates for VS2022 and if so, apply them? Also are you using a windows PC or a different OS?
Davor Joleski [DevOps Enabler] commented 26th February 2025
yes i have update i'll try later and i will inform you
as i saw from other commentar there is script solution i have only automation script thats probably the point need to update visual studio
