Create/Next buttons are greyed out during element creation in Properties window.
Solved3.65K views16th June 2023Create Button Create Element Disabled Element Creation element properties
Neetu Pandita [DevOps Member]92 16th June 2023 0 Comments
While creating an element, in the 'properties' tab both Next /Create buttons are greyed out.
There is no property added for the element.
This is causing an issue in creating the element for all the 'Views'.
Neetu Pandita [DevOps Member] Selected answer as best 16th June 2023
João Severino [SLC] [DevOps Enabler]14.78K Posted 16th June 2023 0 Comments
The 'Next' button being greyed out is expected as there are no further configuration screens you can navigate to (only back with the 'Previous' button).
Now the 'Create' button being greyed out would lead me to think there is still something mandatory that needs to be configured.
Could you confirm that on the 'edit' and 'views' tabs if you see any mandatory field not configured? These will show up with a red indication.
