Create Correlation Rule through automation
Solved908 views28th January 2025Automation Correlation rule
Amer Hodzic [DevOps Member]784 27th October 2024 0 Comments
Hi Dojo Community,
I was wondering if it is possible to set a new correlation rule through an automation script as I was not able to find any information about this?
Thanks in advance.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th January 2025
Willem Mélange [SLC] [DevOps Member]298 Posted 28th October 2024 0 Comments
Hi Amer,
This is possible by using the UpdateCorrelationRule message. You can find a similar question here: How to enable/disable correlation rule from code? - DataMiner Dojo
