Correlation Rules triggering Audible alerts and Slack Alerts
Solved1.12K views27th June 2025
Juan Chavez514 26th March 2025 5 Comments
Is there a way or anyone use Correlation Rules to trigger Audible alerts (to a PC client running VLC) and Slack Alerts at the same time?
Juan Chavez Selected answer as best 27th June 2025
Tobe Deprez [SLC] [DevOps Advocate] commented 31st March 2025
From previous questions, I've deduced you are already able to trigger Slack alerts. Is the problem that you don't know how to set up the audible alerts? It should be possible using an automation script, but I would have to investigate myself. Once you have that, you should be able to add both automation scripts (slack alert and audible alert) to the correlation rule.
Juan Chavez commented 31st March 2025
Thanks @TobeDeprez
Im also looking into getting script for Audible Alerts and how to combine them into one script so its applied to one Correlation Rule.
Tobe Deprez [SLC] [DevOps Advocate] commented 1st April 2025
OK, I don't have a full answer for you, but I did a quick search, and I can provide some links to help you get started.
It seems the easiest way would be to set up a VLC web interface on the PC client (see https://wiki.videolan.org/Documentation:Modules/http_intf/#VLC_2.0.0_and_later and https://www.reddit.com/r/selfhosted/comments/z5803x/remote_audio_player/). Then, you can control VLC via http requests as documented at https://wiki.videolan.org/VLC_HTTP_requests/. If you first set up the playlist correctly on the PC client, a request like http://127.0.0.1:9090/requests/status.xml?command=pl_start should work. You can use HttpClient to send HTTP requests in C# https://learn.microsoft.com/en-us/dotnet/fundamentals/networking/http/httpclient.
Juan Chavez commented 4th April 2025
Thanks Tobe, I read through the documentation. At a glance this focuses on the web interface, I actually have a Rednet A16R interface and vlc running on separate clients. These are interconnected using Dante Controller on the same network where audio channels are mapped.
What Im trying to figure out if we can achieve both audible and slack notification within the same correlation rule (that dev work is out of my league)
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th June 2025
Hi Juan,
Juan Chavez514 Posted 4th April 2025 0 Comments
HHere you have VLC Player, the RedNET interface converts Analogue to Dante, Dante controller simply maps the channels Audio out of client pc to the interface which is fed to our intercom panels as ASI audio
