Correlation Rules, Old Engine
Solved2.08K views22nd June 2022Correlation old engine
Manuel Gallardo [DevOps Advocate]769 20th January 2022 0 Comments
I need to migrate correlation rules between two DMS. I can see the new rules in the Correlation folder but not the old engine rules, where are they located?
Thanks in advance!
Manuel Gallardo [DevOps Advocate] Selected answer as best 22nd June 2022
Matthias Declerck [SLC] [DevOps Advocate]2.99K Posted 21st January 2022 0 Comments
Hi Manuel,
As Pieter-Jan suggested, you can copy the correlation content of the Brain.xml which located directly under C:\Skyline DataMiner\ directory.
I do want to mention that you can still add old Correlation rules via DataMiner Cube as a workaround if you can't import via Brain.xml
Matthias Declerck [SLC] [DevOps Advocate] Answered question 21st January 2022
