Correlation rule – filter based on a view sometimes not executed
Solved909 views24th June 2025alarm grouping Correlation rule
Trong Huynh [DevOps Advocate]881 23rd June 2025 0 Comments
Hi Community,
I have a view that contains 100+ services. All these services take parameters from a few elements.
I have a correlation rule. Its objective is to send an email for every service that is in alarm (technically it runs a script that sends the email because I need the script to perform some checks before sending the email).
The issue I'm running into is sometimes when multiple alarms occur, not all alarms trigger the script.
Note also, since the services rely on a few common elements, 1 alarm could affect several services. We only need the script to run once per alarm, because the script can loop through and send an email for each service affected by the alarm.
Any help to achieve the objective would be much appreciated.
Here's the screenshot of my Correlation Rule.
Trong Huynh [DevOps Advocate] Selected answer as best 24th June 2025
Catarina Grilo [SLC] [DevOps Enabler]2.96K Posted 23rd June 2025 0 Comments
Hi Trong,
To trigger the correlation rule for every single alarm, you need to enable the Trigger on single events. Don’t maintain active tree status.
Ref: General configuration of Correlation rules | DataMiner Docs.
Catarina Grilo [SLC] [DevOps Enabler] Answered question 23rd June 2025
