Correlation – Move from old engine to new Correlation module
Solved1.18K views9th August 2024Correlation Correlation old engine Correlation rules
Catarina Grilo [SLC] [DevOps Enabler]3.58K 8th August 2024 0 Comments
I have some correlation rules that were created a long time ago using the old engine, so their configuration is stored in the SLBrain.xml file.
However, I want to transition to the new Correlation module. Is there a tool available that can simplify this migration, or will I need to do it manually by creating all rules again but using the new module?
Catarina Grilo [SLC] [DevOps Enabler] Selected answer as best 9th August 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.65K Posted 8th August 2024 0 Comments
Hi Catarina,
As far as I know, there is no migration tool that allows you to migrate old correlation rules to new engine. You will need to manually create the correlation rules.
