Correlation Engine: “Test rule” doesn’t result in a hit, despite functional rule
Solved1.03K views21st May 2025Correlation Correlation rule rules test test rule
Nils Hoven [DevOps Advocate]1.55K 9th May 2025 0 Comments
we are working quite a lot with correlation rules. We know (more or less) our way to make the rules work, by starting the definition of rules at a very basic level when filtering for alarms, and from there on going deeper into the details, while continuously testing the rule during the implementation. So generally speaking the correlation engine is performing as expected and to our satisfaction.
However, what we experience is that the "Test rule" functionality often delivers no results, even when we just successfully tested the same rule with real alarms. We cannot see what might be the reason for that - any ideas?
Just yesterday we did just that: successfully testing a correlation rule by triggering it with real alarm events. Then, after bringing the system back to normal, clicking the "Test rule" button and applying the last week time window (there should have been multiple hits):
Any thoughts? What are we missing?
Pieter Van Compernolle [SLC] [DevOps Enabler] Selected answer as best 21st May 2025
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 9th May 2025 1 Comment
Hi Nils,
I believe this is a software issue.
Can you please forward the details to techsupport@skyline.be?
Nils Hoven [DevOps Advocate] Posted new comment 9th May 2025
Nils Hoven [DevOps Advocate] commented 9th May 2025
Hi Ive,
I was afraid that might be the case, but I wanted to give it a try here in Dojo… will do!
