Connection String Configuration additions failing on machine in the cluster
Solved1.01K views18th April 2023connection uris
ryan yahia900 17th November 2022 0 Comments
Hello All,
On the client test tool Advance -> Edit Connection URIs, I am not able to add in new connection URIs for an agent in the cluster. I have logged into the client test tool with an admin account which is shared by all agents in the cluster and used that user and password to set up the connection URIs when entering them and saving them I get the message:
Updating the connectionstring for ‘{DMA1 => DMA2}’ failed. Reason: “failed to connect to ‘{DMA1}’ previously (Unable to authenticate as ).”
Any idea as to why this is occurring I know the Admin account and password are correct as I am using them on other machines without this failure.
ryan yahia Selected answer as best 18th April 2023
Wouter Demuynck [SLC] [DevOps Advocate]6.75K Posted 21st November 2022 0 Comments
I’m assuming that the SLNetClientTest tool was connected to DMAX while attempting to make this configuration, and that the connection from DMAX to DMA1 had a problem (maybe also in need of a connection string configuration for DMAX -> DMA1). In this case, the configuration needed to be forwarded to DMA1 to be saved there locally, and the failure is about this forwarding step.
An alternative would be to connect to DMA1 directly using SLNetClientTest to configure this DMA1->DMA2 connection string.
