Connecting to a DaaS system with Client Test tool
Solved1.81K views31st May 2024
Reinout Daels [SLC] [DevOps Member]787 31st May 2024 0 Comments
Is it possible to connect to a DaaS system using the Client Test tool on my pc? I've tried to connect to host 'mysystem-myorg.on.dataminer.services' with my username and password but get the following error:
Reinout Daels [SLC] [DevOps Member] Selected answer as best 31st May 2024
Jordy Ampe [SLC] [DevOps Advocate]2.00K Posted 31st May 2024 2 Comments
Hi Reinout,
I just tried it with my local agent where it works out of the box with my windows user. For DaaS I suspect you will need to select 'Explicit credentials' and fill in your username and password, can you confirm?
Also make sure to not put http:// or https:// in front of the host URL.
Connection type is on Autodetect here for my local agent, but I suspect for a remote connection to DaaS that gRPC will be used.
Wkr
Reinout Daels [SLC] [DevOps Member] commented 31st May 2024
Hi Jordy, thanks for your reply! I answered in a new reply on my question in order to be able to insert an image.
This did indeed work as you described, using the latest version of Clien Test tool. Thanks!
