Connecting to a DaaS system with Client Test tool
Solved1.91K views31st May 2024
Reinout Daels [SLC] [DevOps Member]787 31st May 2024 0 Comments
Is it possible to connect to a DaaS system using the Client Test tool on my pc? I’ve tried to connect to host ‘mysystem-myorg.on.dataminer.services’ with my username and password but get the following error:
Reinout Daels [SLC] [DevOps Member] Selected answer as best 31st May 2024
Jordy Ampe [SLC] [DevOps Advocate]2.00K Posted 31st May 2024 2 Comments
Hi Reinout,
I just tried it with my local agent where it works out of the box with my windows user. For DaaS I suspect you will need to select ‘Explicit credentials’ and fill in your username and password, can you confirm?
Also make sure to not put http:// or https:// in front of the host URL.
Connection type is on Autodetect here for my local agent, but I suspect for a remote connection to DaaS that gRPC will be used.
Wkr
Reinout Daels [SLC] [DevOps Member] commented 31st May 2024
Hi Jordy, thanks for your reply! I answered in a new reply on my question in order to be able to insert an image.
This did indeed work as you described, using the latest version of Clien Test tool. Thanks!
Reinout Daels [SLC] [DevOps Member]787 Posted 31st May 2024 1 Comment
Hi Jordy,
Thanks for your reply! This is what my Client Test tool looks like:
I assume I have an older version of the Client Test tool. Do I need to upgrade my local DataMiner system to get the latest version or is there a quicker way?
Jordy Ampe [SLC] [DevOps Advocate] Posted new comment 31st May 2024
Jordy Ampe [SLC] [DevOps Advocate] commented 31st May 2024
I’m not sure if the client test tool is included in an update of the Skyline Taskbar Utility (and where to find an update for this utility either). Otherwise yes you will have to update your local DM to have a newer version of the client test tool.
