ConnectAppAndInfoUsingTicket – how to get value for connection ticket
Solved642 views18th August 2025APIv1 login
Tim Vandenbruwaene [SLC] [DevOps Member]2.24K 18th August 2025 0 Comments
In "api/v1/Soap.Asmx?op=ConnectAppAndInfoUsingTicket" it mentions you can connect using a connection ticket.
(<connectionTicket>string</connectionTicket>)
How/where can I get the value for the connectionticket?
Tim Vandenbruwaene [SLC] [DevOps Member] Selected answer as best 18th August 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.53K Posted 18th August 2025 0 Comments
Hi Tim,
You can get a connection ticket by using the 'RequestLoginAsTicket' endpoint in the JSON/SOAP API. Note that this request needs a valid connection, which you can get by using the 'ConnectApp' endpoint in the JSON/SOAP API.
Note that the 'ConnectApp' endpoint needs valid credentials to setup the connection. This is because the ticket login is not meant to be used standalone but to authenticate an already connected user without needing their credentials.
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 18th August 2025
