Configuring SMTP for a Failover pair
Solved1.23K views19th March 2025email SMTP
Rajesh R [SLC] [DevOps Member]746 17th March 2025 0 Comments
Hi All,
A User is setting up configurations to send outgoing email from a 1+1 Failover system. It is clear the SMTP settings need to be configured on both the DMAs and accessibility with the SMTP server be established.
The user wishes to know if the VIP address also needs to be reachable to/from the SMTP server? The DMA servers’ IP addresses and VIP address belongs to a different subnet than the SMTP server. Hence, this query to ensure all firewall rules and routing is configured properly.
Thank you in advance.
Rajesh R [SLC] [DevOps Member] Edited question 19th March 2025
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.36K Posted 17th March 2025 0 Comments
Hi Rajesh,
When configured with a virtual IP, the FO pair will always use the VIP to communicate. So the SMTP server should be able to reach the Virtual IP.
Rajesh R [SLC] [DevOps Member] Selected answer as best 18th March 2025
