Configuring DIS for a Cloud DMA utilising a SAML connection
Solved2.12K views21st February 2024DataMiner Integration Studio SAML Visual Studio
Garry Metcalfe [DevOps Member]156 1st August 2023 0 Comments
I am using Visual Studio 2022 and I am attempting to configure my DIS extension to connect to an AWS EC2 hosted DMA. The authentication protocol required is SAML. It is however not working correctly.
The SAML connectivity works correctly when used in other applications, and I am wondering if there are any particular configuration steps I need for SAML.
Michiel Oda [SLC] [DevOps Advocate] Answered question 21st February 2024
Michiel Oda [SLC] [DevOps Advocate]3.84K Posted 21st February 2024 0 Comments
Hi Garry
As of DIS 2.47, this is now supported: What's new in DataMiner Integration Studio (DIS) v 2.47 - DataMiner Dojo
