Configuring ‘Context engine ID’ in a failover pair
Solved935 views1st July 2024SNMP Manager
Bing Herng Chong [SLC] [DevOps Advocate]1.55K 21st June 2024 0 Comments
Hi, is it possible to configure a different ‘Context engine ID’ per DMA in a failover pair?
Context:
This is the failover pair setup:
It is observed that if the following SNMP Manager is configured:
Whether it is ‘WIN-MBSU9QRGMFU’ or ‘WIN-DFG8R3DI1OO’ that is active, the same ‘Context engine ID’ is sent in the forwarded trap. Is it possible to configure a different ‘Context engine ID’ per DMA in a failover pair? It would also be helpful to provide the reason behind why this is not supported if it is not possible.
Bing Herng Chong [SLC] [DevOps Advocate] Selected answer as best 1st July 2024
Davy Degrande [SLC] [DevOps Advocate]1.77K Posted 28th June 2024 0 Comments
Hello Bing,
This configuration is done on an SNMP Manager level and since these are fully redundant in a failover setup, it takes over the same settings. Currently there is no option to override this configuration to behave differently in a failover setup.
