Column delineation and readability
Solved2.33K views18th July 2023columns delineation Trend icon
Ryan Beaulieu 10th November 2021 0 Comments
Hey all,
When viewing metrics for devices, the Trend icon is always left justified. Without column delineation, it is common for users to mistake the Trend icon’s association due to how the numbers appear grouped with the icon. Are there any options available to allow for adjusting the Trend icon placement or improved user readability for distinguishing columns, such as dividing lines between columns or alternating column background color?
Thanks
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 15th November 2021 0 Comments
Hi Ryan,
If you ‘Enable heat map on table parameters’ in the User settings/Data Display, the icon is visually more connected to the value, like you can see below:
Maybe you try that?
Ryan Beaulieu Posted 10th November 2021 0 Comments
Screenshot for reference.
Ryan Beaulieu Answered question 10th November 2021
