Client Test Tool error: Edge WebView2 component is not installed
Solved1.55K views21st February 2025
Julio Riambau [SLC] [DevOps Member]302 20th February 2025 0 Comments
This error is showing but the component is already installed.
Could you please advice how to troubleshoot this situation?
Thank in advance.
Julio Riambau [SLC] [DevOps Member] Selected answer as best 21st February 2025
Bert Buysschaert [SLC] [DevOps Advocate]5.07K Posted 21st February 2025 0 Comments
There is a DLL missing in our upgrade packages, see DCP222713. For the time being you can grab an SLNetClientTest tool from my OneDrive share that contains the missing files and extract it anywhere to run.
