Clear parameter values on Tables
Solved2.22K views27th May 2025driver option protocol.leave SetParameterDescription
Jose Araujo [DevOps Advocate]1.01K 25th May 2025 0 Comments
Hi
I need to clear table 1100 — that is, delete all its values.
I tried running this QAction, but it didn't work.
1100 is table
1001 is parameter
1002 is parameter
1003 is parameter
1004 is parameter
(This part of QAction delete table)
object[] columnClearInfo = { 1100, 1101, 1102, 1103, 1104 };
object[] columnClearValues = {
newobject[0], // PK
newobject[0], // UUID
newobject[0], // Name
newobject[0], // State
newobject[0], // Chunking
protocol.NotifyProtocol(220, columnClearInfo, columnClearValues);
<Paramid="1101">
<Name>ServiceTableUUID</Name>
<Description>UID</Description>
<Type>read</Type>
<Interprete>
<RawType>other</RawType>
<Type>string</Type>
</Interprete>
<Display>
<RTDisplay>true</RTDisplay>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1102">
<Name>ServiceTableService</Name>
<Description>Service Name</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1103">
<Name>ServiceTableStateService</Name>
<Description>Service Status</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1104">
<Name>ServiceTablechunk</Name>
<Description>Chunk</Description>
<Type>read</Type>
<Interprete>
<Type>string</Type>
</Interprete>
<Display>
</Display>
<Measurement>
<Type>string</Type>
</Measurement>
</Param>
<Paramid="1100"trending="true">
<Name>ServiceTable</Name>
<Description>Table Of Services</Description>
<Type>array</Type>
<ArrayOptionsindex="0"options="key" >
<ColumnOptionidx="0"pid="1101"type="retrieved"options=";save" />
<ColumnOptionidx="1"pid="1102"type="retrieved"options=";save" />
<ColumnOptionidx="2"pid="1103"type="retrieved"options=";save" />
<ColumnOptionidx="3"pid="1104"type="retrieved"options=";save" />
</ArrayOptions>
<Information>
<Subtext>
<![CDATA[Table Of Services]]>
</Subtext>
</Information>
<Display>
<Positions>
<Position>
<Page>Services</Page>
<Column>0</Column>
<Row>0</Row>
</Position>
</Positions>
</Display>
<Measurement>
<Typeoptions="tab=columns:1101|0-1102|1-1103|2-1104|3,width:350-220-112-100,sort:STRING-STRING-STRING-STRING,lines:10,filter:true">table</Type>
</Measurement>
</Param>
Jose Araujo [DevOps Advocate] Selected answer as best 27th May 2025
Joshua Wong [SLC] [DevOps Advocate]649 Posted 27th May 2025 1 Comment
Hi Jose,
ClearAllkeys as mentioned by Miguel should work but if it doesn't, could you give more clarity to the situation you are facing?
When do we want to clear the table? Perhaps we want to make the table volatile if we want to clear the table on restart?
Do we need to save all the table columns?
What are we doing to fill up the table? is the fillarray being done right after we do protocol.ClearAllKeys(1100)?
Jose Araujo [DevOps Advocate] Posted new comment 27th May 2025
Jose Araujo [DevOps Advocate] commented 27th May 2025
Hi Joshua,
I initially tried using protocol.ClearAllKeys(1100);, but it didn’t seem to work. Then I changed it to assign the result to an object like this:
object result = protocol.ClearAllKeys(1100);
and it started working. I'm not sure why storing the return value made a difference, but it resolved the issue.
