Cisco Nexus – Why is parameter PTP Username reset to default after element restart?
Solved3.08K views9th September 2020CISCO Nexus protocol
6
Jens Vandewalle [SLC] [DevOps Advocate]10.09K 9th September 2020 0 Comments
I'm running protocol Cisco Nexus version 3.0.0.23 and notice that after an element restart parameter PTP Username (PID 11200) is reset to its default value No Credentials (raw value "-1").
Following items are checked from my side:
  • Protocol has no after startup logic
  • Parameter contains attribute save="true"
  • Found no reset-to-default logic in the QActions nor in the trigger-action combinations
Does someone knows why this happens?
Jens Vandewalle [SLC] [DevOps Advocate] Selected answer as best 9th September 2020
João Severino [SLC] [DevOps Enabler]14.78K Posted 9th September 2020 3 Comments
Are you setting the username to something valid or is it set to an empty string?
If a parameter is set to an empty string it will revert to the default value defined in the protocol after a restart.
João Santos [SLC] Posted new comment 9th September 2020
Jens Vandewalle [SLC] [DevOps Advocate] commented 9th September 2020
It is set to something valid
João Severino [SLC] [DevOps Enabler] commented 9th September 2020
Are you testing the element alone or as part of the PTP solution?
João Santos [SLC] commented 9th September 2020
Indeed, as João Severino said, if you are using it as part of the PTP Solution it might be related with that. Just tested on a different setup (no PTP Solution) and it is working as expected. Credentials are being kept.
