ChatOps Login Problem
Solved1.73K views6th May 2024ChatOps login TeamsChatOps
André Camões [SLC] [DevOps Advocate]575 3rd May 2024 2 Comments
Hi Community,
I'm having trouble with the login process for my ChatOps operator. Is there any trick I can use to overcome this problem?
André Camões [SLC] [DevOps Advocate] Selected answer as best 6th May 2024
Jordy Ampe [SLC] [DevOps Advocate] commented 6th May 2024
Hi André, this is an issue at our side, we will investigate and come back to you.
André Camões [SLC] [DevOps Advocate] commented 6th May 2024
Alright, I’ll wait for your feedback. Thanks @Jordy
Jordy Ampe [SLC] [DevOps Advocate]2.00K Posted 6th May 2024 0 Comments
the issue has been resolved. Updated the status on DCP Status (dataminer.services).
Wkr
