ChatOps – ChatIntegrationHelper, best way to format notification
Solved2.24K views29th September 2023ChatOps TeamsChatOps
Robin Meurisse [SLC] [DevOps Advocate]1.51K 28th September 2023 0 Comments
Hi Community,
We would like to post a new notification in a MS Teams channel when a certain activity happens in a cloud connected DMS. Basically an automation script will use the ChatOps extensions to send a notification to a channel.
This works great!
chatIntegrationHelper.Teams.TrySendChannelNotification(teamId, channelId, notification);
Question on the notification itself: the notification is currently a plain string, would it be possible to pass along an AdaptiveCard (Teams style) or other format to present a nicer notification?
Thanks in advance!
Robin Meurisse [SLC] [DevOps Advocate] Selected answer as best 29th September 2023
Jordy Ampe [SLC] [DevOps Advocate]2.00K Posted 28th September 2023 2 Comments
Currently for Chat Integration only text is supported. This would be something Domain Cloud Ecosystem could implement but it’s not planned on our road map right now.
(For Custom Command it is possible to use Adaptive Cards already.)
Wkr,
Jordy Ampe [SLC] [DevOps Advocate] Posted new comment 2nd October 2023
Robin Meurisse [SLC] [DevOps Advocate] commented 29th September 2023
Note: for anyone trying to create a chat or channel notification, it’s possible to use HTML tags to have a nice formatted message.
E.g. h2-tag to create a title, br-tag for a newline etc.
Is this something intended? Should we add it to the docs to indicate that this is possible?
Jordy Ampe [SLC] [DevOps Advocate] commented 2nd October 2023
That indeed might work. But note Teams is not very consistent in supporting everything across different platforms (desktop, Android, IOS). See their support for text message formatting here: https://learn.microsoft.com/en-us/microsoftteams/platform/bots/how-to/format-your-bot-messages#format-text-content
