Changing Index Engine Backup Path in Cube
Solved1.68K views17th March 2023backup path DataMiner Cube Elasticsearch
Ryan Hepworth [DevOps Advocate]1.55K 10th February 2023 1 Comment
Hi Community,
I am trying to change the Backup Path for ES in cube, however I keep getting the following and the path does not get changed. I have updated all info on the Task Scheduler however the changes still wont take.
Has anyone else had the same or know an extra step I am missing, or is the only way to do it properly through the DMA itself?
Ryan Hepworth [DevOps Advocate] Selected answer as best 17th March 2023
Toon Casteele [SLC] [DevOps Enabler] commented 10th February 2023
Could you share the content of the SLSearch log file, as well as the backup path you tried to configure (feel free to leave out sensitive information where needed)?
Ryan Hepworth [DevOps Advocate]1.55K Posted 10th February 2023 2 Comments
Path is:
\\computername\DAZN_Database_Backups\DEV\Elastic
Alex Silva commented 10th February 2023
Are you able to access this path (and read / write content) from the related servers?
Do you need authentication to acces this path?
There are some path restrictions:
https://docs.dataminer.services/user-guide/Advanced_Functionality/Databases/Elasticsearch_database/Configuring_Elasticsearch_backups/Configuring_Elasticsearch_backups_Windows.html?q=IndexingEngineBackupPath#restrictions-for-the-backup-path
Ryan Hepworth [DevOps Advocate] commented 10th February 2023
We already have a task in task scheduler with all the relevant login details, just edited the existing schedule to replace the old name with the new name.
