Changing Cassandra and OpenSearch hostname
Solved1.29K views21st June 2023Cassandra hostname opensearch
Laszlo Szabados [DevOps Enabler]304 19th June 2023 0 Comments
Is it possible to change the hostname of the servers running Cassandra and OpenSearch on Ubuntu?
Other than modifying the hostname on the OS level, are there any settings/procedures on application level to be taken care of?
Laszlo Szabados [DevOps Enabler] Selected answer as best 21st June 2023
Michiel Saelen [SLC] [DevOps Advocate]6.34K Posted 21st June 2023 0 Comments
Hi Laszlo,
If you are using the IP addresses everywhere and not hostnames, then there should be no problem changing the hostname of the server. I would still recommend if you are doing these types of actions, to always first do it on your staging/demo environment before doing this on a production environment.
